thanks for the vote in confidence. im hoping to have it back in the truck by the end of next week. i have to wait for a torque angle gauge to come in tomorrow and finish up the rods. im going to try to get the rear main seal on with it on the stand so i can button up the bottom and call it good.
decided to go ahead and paint the cylinder heads to test the paint. looks pretty go i think. not perfect, but will definitely show leaks. used duplicolor hi temp chevy orange DE1620
installed timing gear, will be doing heads shortly. timing is intake opens ~6* early closes ~2* early. margin of error is there since we kinda jerry rigged a timing indicator and degree wheel.
Beautiful, hope it goes better than my recent work.... (just replaced the top end on my father in laws 94 ranger (4.0l), topped off coolant, fixed/filled AC, ran in garage like 30 min or so and when I went to back the thing out it died and would not restart... Burnt up an ECM...... literally......
Thanks. The damper shaft bolt got kinda dicked up so I hope it doesnt let go. How did the ecm burn up? I havent heard of that happening very often. But when it did it was always a ecm failure
I dont really know.... I have triple checked all the wiring, I suspect it has something to do with the fact it is 19 years old and a Ford...... But I digress.......
I have been cussing this thing since I got it.....
