clp71220
- Aug 3, 2008
Leaning an engine out does not make more power. That is a common misconception and one that is incredibly wrong. At closed loop, you're running at approximately stoichiometric (14.68:1). At 12.5:1, best power will be achieved on most tahoes on this site. Leaner than 15.5:1 and you'll start to waste fuel, as the power will drop significantly enough that it will take more throttle to maintain speed.
Arbitrarily leaning out the fuel mixture will have fleeting effects with a closed loop system, as the computer will just compensate by adding even more fuel in.
None of this addresses the fact that it takes energy to create the "HHO", energy that cannot be fully recouped, since the thermal efficiency of a four stroke ICE is less than 50%...
What kind of guarantees do these guys make, if any?
You might contact them and see if you can become an installer and tuner for them there is already 7000 people involved to my understanding. The addition of the HHO increases the volume of fuel. HHO has 5 times the combustion than fuel does using monatomic Hydrogen and Monatomic oxygen. The HHO is a Fuel enhancer causing the fuel to burn in the motor instead of the Cat. The Guarentee is that you get 50% better mileage or your money back most all vehicals get 100% to 200% increase with the HAFC. The fact that the electronics are being addressed makes all the difference. With this you must lean out the vehical. The energy used to produce the HHO is a factor but the gains more than pays for itself.
