RenegadeTahoe
- Aug 13, 2008
Right, but that coil is powered by (pulsed) 12V, correct? Still 1,000,000 watts no matter what side of the coil you are on. You only increase the voltage and drop the current when stepping up voltage, the Watts are the same. Did the original add mistake Watts for Joules?
I won't even pretend to know... but this is what I found...
http://www.redherring.com/Home/22376
“Virtually all spark plugs today have 50 watts of peak discharge power,†said Enerpulse Chief Executive Daniel Parker. “What we’ve found out is that by putting a pulse circuit on top of a spark plug, we can increase spark plug output by [up to] 1 million [watts].â€
So, you figure... standard plug w/ high-voltage coil = 50w / 40,000v = .00125a
That seems like a better number... but 25a isn't that far fetched.. with the right circuit.
