CRXMotorsports
Sorry for my delay in replying Chris M.
The guy who posted below mine appears to have a newer model than this disscussion forum (which is for 94-99s). There is no towing mode button on this generation.
I found this on another site.. the code is found in the glovebox to coorespond to these ratios.
GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION)
HC4 -- AXLE REAR, 4.56 RATIO
I don't believe the tow package touched the suspension what-so-ever. I'd say milage is approximately 13 (+/-1)mpg, not bad at all.. I cruise at 65, not a speed freak by any means...
I purchased the Yukon from a long time racer and friend. he had put 140k+ on it, and just had the transmission REPLACED as well as new tranny coolers and lines in front of the radiator. I think he said he put $2000+ into it.. he was stuck in Chicago when it went poof... he replaced it whereever he could get it done... he towed with it for the full 10 years (1997-2007) and I tow with it now also.. (talk about abuse!!)..
