Traded My 04' Sierra for 04' Tahoe
Mr.Klean
Thanks, d piller look good, so the vents in the oem d's have no function?
L.E.D.'s look so clean.
How much do they run, the ones I saw on k2motors.com that look like that were $209.
No sir the vents don't have any function that I know of..
I think you can buy them off of Ebay for 149.00 with shipping. The brand is Sonar that I have and majority of the members have on here..
tast101
Colton, CA
heres some night time shots
CHISTOSO
Tempe, Arizona
[/IMG]
Here's another shot of a silver Hoe with the LEDs. I also have a pair of smooth vent caps I got from a member here waiting to get painted..
heyrokendenali
Colorado
LED Tail light issue
Hi All,
I just received a pair of LED tails just like the ones you all have posted pics of. Unfortunately, I am unable to get the brake/running light to function on either side. The turn signal works as does the reverse (since no bulb change was necessary for the reverse light). I plugged the brake socket into the top plug and the turn signal into the middle plug as labeled on the back of the tail light assembly....and nothing!
Both light sockets were functioning fine prior tol install and then this. So to test them I put in the regular bulbs again and now they aren't working at all! Has anybody ran into the same issue? Could it be a fuse?
On the installation instuctions, it says to change the connections if it fails to work, but the picture on Sonar's install sheet are so poor I cannot make out how to remedy the problem. I am hoping someone can help me out. THANKS!!!
