Recover headlinerRepair History 2005 Tahoe 4X4 Z71 In-Service 1/5/05
This is an update to 130.9k miles; 2/2/18
Repl SDM Module
Reprogram Power Control Engine; Install Exhaust Vibration Damper
Repl Intermediate Steering Shaft and Fuel Level Sensor
Repl Transfer Case Actuator
Repl: L Temp Valve Actuator, Pwr Brake Booster, RR Window Regulator
Repl LR TPMS Sensor
Repl: HVAC Control, R Temp Valve Actuator, Steering Shaft
Repl Lower Column Bearing and L Temp Valve Actuator
Repl Blower Motor Resistor
Repl High Mounted LED Brake Light
Repl Transfer Case Encoder Motor Sensor
Repl All (7) Instrument Cluster Stepper Motors
Repl Canister Vent valve (104.1k mi)
Repl Purge Solenoid
Repl water pump (106.3k mi)
Repl right outside mirror lamp
Repl driver side seat and arm rest covers (114k mi)
Repl rear window lift supports
Repl rear brakes and rotors, AC blower motor, left temp. actuator, instrument panel rheostat (118.8k mi)
Remove gas tank; Repl vapor canister, fuel lines, vent solenoid and fuel pump (121.3k mi)
NOTE: one might consider preventive maintenance to change charcoal vapor canister ~100k mi
Replace front bulbs: Sidemarker (2), DRL (2) DIY cost $14 (123.1 mi)
