The official how many miles on your Tahoe Thread
LOWKEY
Cleveland, Ohio
04 before I traded it in had 240+k on the clock and ran like a champ,
my current 11 Tahoe is at 122k.... still a baby, and rust is starting on all 4 corners, thanks Cleveland for the calcium chloride and rock salt :( !!!
bdaves
Just bought an 02 Yukin, 2wd, 175k miles, for $5k. And just picked up an 02 Yukon, 4wd, 138k miles, for $5200.00. Keep looking.
BamaKurt
Picked up a super clean 2003 Tahoe LT with 240k for $4600. Runs like a champ. Since I have a company car for work, I'm set for a while.
Lowboy
Just traded my 2009 Tahoe LTZ with 171,000 and change. Very few problems over the years. Work horse!
bill77056
Houston, TX
Repair History 2005 Tahoe 4X4 Z71 In-Service 1/5/05
This is an update to 121.3k miles; 10/25/16
Repl SDM Module
Reprogram Power Control Engine; Install Exhaust Vibration Damper
Repl Intermediate Steering Shaft and Fuel Level Sensor
Repl Transfer Case Actuator
Repl: L Temp Valve Actuator, Pwr Brake Booster, RR Window Regulator
Repl LR TPMS Sensor
Repl: HVAC Control, R Temp Valve Actuator, Steering Shaft
Repl Lower Column Bearing and L Temp Valve Actuator
Repl Blower Motor Resistor
Repl High Mounted LED Brake Light
Repl Transfer Case Encoder Motor Sensor
Repl All (7) Instrument Cluster Stepper Motors
Repl Canister Vent valve (104.1k mi)
Repl Purge Solenoid
Repl water pump (106.3k mi)
Repl right outside mirror lamp
Repl driver side seat and arm rest covers (114k mi)
Repl rear window lift supports
Repl rear brakes and rotors, AC blower motor, left temp. actuator, instrument panel rheostat (118.8k mi)
Remove gas tank; Repl vapor canister, fuel lines, vent solenoid and fuel pump (121.3k mi)
NOTE: one might consider preventive maintenance to change charcoal vapor canister ~100k mi
bill77056
Houston, TX
This is an update to 123.1k miles; 12/13/16
Repl SDM Module
Repl LR TPMS Sensor
Repl Purge Solenoid
Replace front bulbs: Sidemarker (2), DRL (2) DIY cost $14 (123.1 mi)
Streettoyz22
Help pls anybody
My truck won't turn on ! I have a Chevy Tahoe 2 dr , 5.7 vortec . I struggle to turn it on at times has a new starter and battery, new spark plugs and spark plug wires ! 2 weeks ago I ran it on the scanner and 2 codes came up it was the crankshaft sensor and the camshaft sensor , so I replaced them bt still struggling to turn it on ! Any ideas ?
BlackedOut01
Just a beater
2001 LT 5.3 4wd (I've only owned it for a month or so but it was a great deal)
Currently at 183k miles and runs and shifts strong
Recently replaced:
-All brakes and rotors
-Front right wheel bearing
Needs:
-Driver door panel
-Driver fender and door (ditched by previous owner)
-Body work on rear quarter (Also ditch damage)
-Need to find a new spare
-Needs new speakers
-Will need a tune up soon (check engine light on, cylinder 2 misfire)
-Needs new coolant res. (sensor is jacked so the light stays on)
-New fuel level sensor (low fuel light stays on)
foxxycat
northeast
2006 Yukon 4x4 214,000 miles. haven't had any major issues other than something wrong with the differential as it looked like someone tried to repair it- I bought it in 2010 with 78,000 miles on it= and I haven't touched the rear end since-the change over was in 2015,,probably at 170,000 miles..I can't remember.
I have had the usual=brakes, tune up twice, tires. had to replace the stainless steel lines to the transmission and a few smaller things. Engine no problems. Transmission only done the screen and fluids a few times.
It has a weird noise lately but we are still trying to figure out what it is. I can't complain. It's comfortable, powerful and never left me stranded. I have heard that the earlier years had some issues but I think the 2006 may have cleared up any issues.
Looking to upgrade to a newer one but worry that the newer vehicles have more problems than the older ones due to cost cutting measures of using lesser quality materials etc. Can't complain. I hope to get another year or two out of it..as someone said-told me to drive it until it grenades.
Buckeyetroop
85k miles. Seeing all of these high mile trucks makes me pretty confident about my purchase.
MRH1958
2003 Tahoe LT/5.3 4WD W/Autoride........130,000 runs great only have had normal service like brakes, rotors, A/C ,etc. Runs strong so far, fingers crossed
Jeremy78
My 99 has 243000 on it. I've had it for about 10 years and have done pretty much nothing to it beside the basics. Unfortunately now it's starting to give me problems but I'm not complaining!
lhbeery
gotta be up there
I have 494,000 on my 02 z71. I have replaced everything at least once. when it gives up, I plan on burying it in the back yard and making it into a hot tub.
hcauto74
1999 Tahoe Upgrade
I'm having a lot of trouble figuring out what size bulbs go in the HVAC control unit. ive seen several videos but none of them have the same unit has mine. i need help!!!!!
desertevac
Illinois
bulb size
I took a look at a replacement control head I had, they say Toshiba V-2. Small tiny bulbs. Hope this helps.
desertevac
Illinois
