but i would not feel comfortable having 100 watt bulbs in my highs, that would melt the housings. enless you have had no trouble.
This may seem unrelated, but you'll see the point--
I've ben a biker for nearly 40 years in the saddle. And specifically a Gold Wing owner since 1978. My last Wing was a '96 GL-1500 Aspencade.
Since 1988, Gold Wings have had dual headlamps. The headlamp housings are made of ABS plastic, with mirrorring on the inside surface, and mineral glass on the front. For years I was active on the "Wings on the Internet" mailing list, and over those years the discussion of hot bulbs was brought up regularly.
There's a group of Wing owners who insist that hotter-than-stock bulbs will melt the wiring, the headlamp housing, or both. Especially with extended use.
For 10 years, I ran either 100/80 watt bulbs or 130/100 watt bulbs in my Wing. I made uncounted runs in endurance rallies where the lights were never turned off for up to 24 hours at a time. I even tested to see if the wires got hot. In 10 years of running those bulbs, the wires never even got warm to the touch, and the lamp housings never melted or degraded in any way. (I did not continue to use 130/100 bulbs because the wiring could not supply the current they needed for full brightness, without installing larger wires and relays. Call me lazy!)
To summarize-- When you talk about running hotter-than-stock bulbs, there will always be a group of nay-sayers who will insist that your lamp housings will melt, the lenses will melt, the wires will burn, or your vehicle will explode in a mushroom cloud.
The truth is, if the wires aren't large enough, the bulbs simply won't burn full brightness. The wires won't get that hot because the bulk of the resistance in the circuit is in the bulb, and that's where the heat occurs. The stock wiring on a Tahoe will easily handle 100-watt bulbs.
100 watts will not generate enough heat to damage the housings or lenses. I mentioned the Wing lenses were mineral glass. And yes, I know the lenses on a Tahoe are plastic. Specifically, they are polycarbonate (Lexan). If the ABS housing won't melt, the lenses certainly won't melt, either.
100-watt halogens are brighter than OEM replacement HID's, measured in actual light output in lumens. What you "perceive" as brightness has everything to do with light color in degrees, and how the reflectors/lenses of the lamps focus the beams. Bluer light, focussed closer, gives the perception of better vision. But yellower light, focussed farther out, lets you actually see more of what's coming up, and with less glare. (This is what makes Silverstar bulbs "appear" brighter. They have a blue filter on the bulb to remove some of the yellow light, and they are configured to focus the light closer and wider. They actually put out less light than stock halogen bulbs!)
But discussing lights can be like discussing motor oil. What's most important is what makes YOU feel safe and comfortable as you drive at night. I just personally prefer higher-watt halogens, with no blue tint on the bulbs.
