Starting Problems...
TyCoon
The starter may not be grounded very well. Run a jumper cable from the negative terminal and clamp the body of your starter to check this. If the starter works fine with this set-up, then remove the starter, clean the corrosion around it and where it mounts, and reinstall it.
