Rear A/C Problem - Blend Door Broken
MondayNite
Newbie to the forum here. I searched for my particular problem, but didn't find anything specific.
Several weeks ago my rear A/C quit blowing cold air - it only blows hot, like scorching hot. I had read plenty online about the blend door actuators and so I took the inside trim panel off above the passage rear wheel. When I took the acuator motor closest to the rear off, the arm from the blend door came out with it. The actual blend door itself was broken. I tried super gluing it back together but I just made a mess and cut my hands up prying open the evaporator case to work inside.
I have the auto climate control and I have seen evaporator cases on line for about $70 which includes the doors inside, but my question is how hard is it to swap out the whole case? I can pull the heater out of the box (it has the two tubes running from under the truck). But before I order the replacement, I'd like to know if I'm getting in over my head or not.
Thanks for your help.
Scrtcell
You can replace the top half of the rear unit I am not sure what the price was but it is a dealer item and it is available for purchase because of that...
MondayNite
So it's not a difficult replacement? I just have basic skills - oil changes, spark plugs, etc. I don't want to tear something else up trying to fix the air.
Scrtcell
Just remove the panel to access the rear ac unit and you will see all the screws that need to be removed it is very easy...
Scrtcell
Where r u located I live in Maryland and I can do the job for you...
MondayNite
I'm in Memphis, but thanks for the offer. I have the panel off already. I'll order the part and dive in.
fordbeater
I had a broken blend door on my Tahoe and a broken actuator motor that was located underneath the dash and very difficult to access. The repair was going to cost me over $1300 at my mechanic. After some research online, I found a kit called the HeaterTreater and had it installed by one of their affiliate mechanics. It has been working well for a year and a half and it saved me a ton. Just wanted to pass this on to anyone struggling with broken blend doors. It's a problem you don't want to worry about. :happy160:
