Well, after seeing the awsome pics from TwinTT and Pete, I got the same Perma-Cool kit... I love it!
It looks great... and the fans are remarkably quiet. I also threw in a 160* thermostat, and I don't really hear my fans going off very much. I also have a short drive to work, so maybe they're just not getting hot enough. I even turned down the 'on' setting.
As for fit, they fit great, and were easy to install, but for some reason, my radiator to fan gap was too big. They recommend .50"-1.00"... and I was way over that. My truck has a replacement radiator (my dad replaced the original yrs ago) so perhaprs it's a bit thin? Anyway, I drilled new mounting holes in the pretty top cover... about .75" back. This put my fans exactly .75" from the radiator fins. Perfect.
I also riveted the stock power block onto the fan shroud... pretty much where it was originally. I used rivets because I was too lazy to remove the fan shroud. If I ever do, then I'll replace the rivets w/ proper nuts and bolts.... but it's really fins as it is right now.
I just have to hook up the AC wire lead... and like Pete, I'm stumped as to which wire to hook it up to. I'm tempted to tap into the blue wire on the AC clutch, but the instructions say to hook up to the Drier. I'll have to call them up on this one... or if anyone knows... please share!
I also want to hook up this same lead to an on-on switch... like TwinTT mentioned. That's a great idea for automoatic AC turn on, and manual turn on.
As for the overall results... the truck is MUCH quieter!... when idle... or while driving... (plus my exhuast is stock, so It's even quieter) It' also seems to be smoother, and yes, it does accelerate a bit better than before. I want to start recording my mpg... but this along w/ my new brake setup is making me drive more aggressive =P and my mpg isn't that great. I'll probably start to record it when I settle down... but overall, I love driving this truck!
Thanks for all the tips fellas!
