TwinTT, when your wiring failed what was happening? I think these fans suction about 20 amps, was it the fan motor wire that failed or something else?
I like the perma-cool more than the flex-a-lite, becuase its metal, etc more professional looking than plastic.
also, how do you set the thermostat sensor? Does it come preset to like, 170-210 neighborhood?
OK, here's the scoop on what happened to my Perma Cool.
Under the passenger side of the Perma Cool fan's assembly, there is a control module that is black, with a Perma-Cool sticker on it. Part number 18905. It has a white multipole 8 pin socket on it. Looking at it with the trim pot on the right hand side, the left upper pin of that connector will have a yellow wire going in. That is the pin that was burned brown and the relay near by had the yellow wire contact melted.
I don't believe that the control module was the culprit here, but rather a situation where one of the fans became impaired and the overload took it out. I did not catch the actual event, but I did have to replace the shear pin on the driver side fan at one point.
The only thing I can think of was that that fan got caught on the K&N air flilter on the drivers side hair dryer. If in fact that was the cause, the Perma Cool in inocent of something, I don't know what just yet. They do seem to be a little light on the internal wiring around the relays. They supply you with what looks like a 8 gauge wire for the power and then drop to 16 gauge on some of the interior stuff.
Since "the event", I have not had any issues. They use a thermister fastened to the sheet metal between the fans to sense the heat of the radiator. It is a very positive way to do it and I'm sure you would like the setup.
I would take the time to solder the crimp on leads inside, but that only takes a few minutes. Or better yet, just eliminate the crimp on's and solder to the relay post's direct.
I can try to see what info came with the fans, if your interested. Let me know. Good luck.....
