Working on a 99 Tahoe 4wd 5.7. I put a long block in it some time back and had a leak from the front of the oil pan from the start. Had someone redo the timing cover/oil pan last year and it went about 1-2 months before it started leaking again. Just replaced oil pan gasket myself and discovered that instructions (I should read more often) stated absolutely do not put an adhesive on the gasket. I had previously put a blob of silicone on the corners of the valley on the front (old habit from the multi-piece gasket days). The last guy that worked on it did the same but he gobbed it on (mostly to fill the hole in the timing cover that he somehow broke when mounting.
So this time I tried it dry. Replaced the timing cover and pan gasket and I'll be damned if it isn't leaking right from the front valley again. The pan was only mildly distorted along the straight edges when I removed and I straightened it. The valleys looked true and undistorted.
Addendum - Redid it today as notice a dent in bottom of front valley. Fixed it really well - all surfaces perfect and still leaked. Appears to be leaking at the corners of the valley. Instructions say DO NOT put silicone on gasket and yet still seems to leak from the corners at front valley.
Any suggestions on getting this to stop leaking?
