SoCal Tahoe
Want to make sure i do it the safest way possible....no scratches or left over marks of any kind are improtant to me.
Any help would be appreciated. Thanks.
removal of badging
I just wanted to chime in here. I have been debadging for years. The best setup I have found is, on a hot day, sit your vhicle in direct sunlight. Then, take some WD40 and drench the badges. Take some 15lb test fishing line and in long steady motion saw behind the badge. You will be left with the 3M and some foam.
Once off, start slowly spraying the foam with WD40 and using your nail peel off the foam. The more fluid and heat the better. Then wash your vehicle by hand. You will need a polish at some point to make sparkle, but the above has worked for me for years.
