Ed Blown Vert
I would really like a set. I want both High/Low, but heard it isn't a good idea.
Stock hids (like BMW, Cadillac, and Lexus) use 4300k, I have this on my truck, They are awsome, their white, with the slightest tinge of blue in them.
do they glare on oncoming traffic?
and i doubt it has a cutoff right?
which kit do i need for lows on a 07 Tahoe? i want something plug and play
i was thinkin 4500K H11 (i think thats the socket size)
and i know the stock bulb is 55W so i guess ill get the 55W
I have the DDM hi/lo H13 set in my 07 Denali and they work great. It works by an actuator that physically shifts the bulb's position within the housing to achieve the OEM high beam pattern. I must say that it works very well. I can't comment on longevity but the solenoid design used seems pretty reliable. One significant advantage that the Hi/Lo H13 kit has that others don't (I could be wrong on this though), is that it came with an integrated harness designed to be wired directly to the battery. From my understanding this is usually an optional add on. Instead of using the existing headlight harness for power, it simply uses the harness for the on/off and hi/lo signal but powers the lights directly from the battery. This not only eliminates the risk of a melted harness, but also ensures a reliable ignition of the bulbs due to effectively limitless current.
If you decide to install an HID kit, I highly recommend removing the entire front end rather than just the headlight housing. I was able to route my wires, ballasts, and igniters in a much more attractive and secure manner than I would have been able to otherwise. The only thing I would do differently is go for the full size ballast (not slim). Space is not an issue, so a separate ballast and igniter is unnecessary.
If you get a 55W 4500k HID kit you are gonna run into some issues;
1. Is that your low beam harnesses will melt unles you get heavy duty H11 connectors or a relay harness for the kit.
2. Your low beams aare gonna be WAY to bright, about 5000 lumens which will piss people off due to the glare from non projecor OEM housings.
Trust, the 35W kit is a smarter decision, 4500k kits is as bright as HID'd get, my 35W 6000k kit is bright as hell, talkless of a 35W 4500k kit!
im gonna order mine tommorrowyou are exactly right on that. They very. I had a 4300k kit from Higher level auto. Was bright yellow (for highs) and a 6000k (for lows until I changed them) and the 6000k was deep blue (like 8k) and the 4300k was yellow like 3000k. The 4300ks on the rado are from VVME.
