nathanbgross
- Aug 14, 2011
I saw some staining on the carpet of the front passenger floorboard in a used 2004 I bought recently and decided to take a closer look. We had driven about 2 hours in the rain w/ the A/C on the entire time and I noticed the floor was very wet. I pulled the mats out and the carpet up and the pad and metal floorboard were wet. It seemed very concentrated in the middle of the floorboard from the 'hump' almost all the way over to the door but not quite. I noticed a bit of tape in the plastic tubing/pipe that presumably runs along the hump and then under the passenger seat to the rear A/C vents that looked to be covering up a hole/crack. But I honestly could not tell if that is where the leak was coming from, although it seemed to be wet around that, downstream from that, and along the front right area of the floor from there too. So it's possible that could be it but again, I'm not sure. Has anyone else had this type of issue and, if so, what was the cause? I saw mention of the possibility of a drain pipe being off or clogged but could not find that and wasn't sure it would only cause this much water. Would REALLY appreciate all feedback or guidance from anyone(s) who has had this type of issue. Thanks!
