hey guys. Ive been thinking about putting LED bulbs im my 99 tahoe headlights. Are they better/worse then HIDs? Ive had HIDs before and was curious about LEDs
Did a set in the low and high beams as well as the 4-hi mod and heavy duty harness while I was in there. They work great and are an easy install. Just be careful positioning them in the housing. The LEDs are on either side of the bulb assembly so if you position them with the LEDs vertical it will not work in a standard housing as well as putting them horizontal.
The ones I got on Amazon are 50W units and I did the high and low and while I was in there I did the 4 hi mod. So it is extremely bright. I am heading upstate this weekend and planning on taking some pictures. I'll get a few of the light output and post them up.
