Garden Hoe
- Oct 28, 2008
So this just started happening.....I could tell that the battery seemed weak. Then today it wouldn't crank, just click. So I jumped it and it was fine the amps read 14 and my lights and locks worked before i tried to start it. Then I shut it down after 10 minutes and tried to restart with no luck. I pulled some fuses and checked the terminal connections. I put it on a charger and it was almost full power. So my question is, how is there not enough power to crank it, but when it's jumped and is running the battery seems to be at full charge??
