Gauge issues on '99 Tahoe
So dash ground is good if lights work.
If check guages light works, then power to dash is good.
You would then probably either have a bad linear motor or a bad connection between gauge and sender..... wire tracing fun fun.....
Pin 13, dark green from dash pinout to sender in left cylinder head is what you want to troubleshoot. might hit up a junkyard for a spare dash if for nothing else but the motors if the wire is good.
Wayne67vert
Central Florida
I checked the wire from the sensor connector to the gauge cluster. The connection is good so that means the gauge is bad.
I have purchased a Scan Gauge that shows motor temperature and I will use it for my Temp gauge.
I had the fuel pump module/level sensor replaced and now the gas gauge works. YEA!
Thanks for the help in this issue. :)
Wayne
