Eliminating A/C odor
jpmaniac87
One: Does this "Module" work for a 2000?
Two: Is it bad to run the AC without havin the filter in its place?
Yes, it will work with your 2000.
The filter helps with the air you breathe, but won't cause any harm to the hvac system if you don't use them. You may notice a quicker accumulation of dust in your vents and cabin in general though.
jpmaniac87
This may be a dumb, and i mean really dumb question, but could it be better to get like an ac filter, like the fiberglass ones from a household ac unit?
The cabin filters for the vehicles are finer than the 'glass home filters, so they trap more dirt and particles from an outdoor enviroment.
ronjeremy6
jk, how do know if i have an in-cabin air filter (what to look for)?
You'll have to look underneath the passenger dash and remove the panel. The access door for the filter has two 7mm screws. Remove this and there should be two filters. Keep in mind this is only available on the 00-02 models.
YukonJacks
PA
