DoABurnout
- Mar 21, 2011
Has anyone had the issue of the A/C circuit not being able to run the relay?? I attached one of the relays to be tripped when the A/C clutch was engaged, but it will only engage both relays for a bout 5 sec until they both kick off. I currently have the fans run through a toggle on that circuit so I just do them manually. Why would the A/C circuit not have enough Voltage to run both relays at once??
