detonating tahoe
wilshire37
boston
hi everyone, new to the site and looking for a little help. i have a 97 tahoe 5.7l 4wd. the problem is a popping/detonation in the intake that travels out the tailpipe at 1500-200rpm only under load. it seems to get worse as the vehicle warms up. the engine has 182,000 and purrs....this is whats new fuel pump(ac delco) fuel filter tps,iac, 8 ac delco rapid fire plugs,complete distributor and wires,crank pos sensor the injection spider was upgraded 4 years ago with a new lower intake. what i know for sure.... timing has been verified with a snap-on scanner in the plus/minus 2 range fuel pressure 62psi running 55/58 when off and holds.. no intake leaks. what i am thinking is a defective egr or coolant temp sensor. oh i forgot to mention no codes at all in the computer. this started after the vehicle sat for 3 months while i rebuilt the rearend. put new gas and seafoam in as well. i unplugged the egr and vehicle kept running smoothly should it have stalled or sputtered??? anyone experience this?? appreciate any help or ideas
07burb
Kansas City, Mo
Moved your inquiry to the appropriate section for you with the hope of getting a quicker response
wilshire37
boston
i figured it out ... was a bad dist.cap put a new one in and she runs perfect!
