Ok,
So i bought this 97 4x4 tahoe for CHEAP about 2 weeks ago. I just needed something to pull the ATV's when we go mudding or hunting. When we test drove it, it was throwing two codes. 1) Evap leak 2)Crank sensor codes.
my buddy is a pretty good mechanic so we dropped the tank and fixed the evap leak (they installed a new pump and never put a seal between the tank and the big ORing.
so one day it wouldn't start and long story short we figured out that the screws holding the rotor down yanked out and we had to replace the rotor (had to use one size up on the screws).. so yes, we have messed with the cap and rotor.
I then REPLACED the Crank Sensor on the front of the motor (behind the harmonic balancer) thinking that should fix the code..
NOPE !! i can not figure out what it is !! i do not know the exact wording but the code is like "Crank Sensor to Cam Sensor off" something to that nature..
Does ANYBODY Have any ideas ?!
Thanks in advanced ! !
