1. Positive goes straight from battery to alternator. This one is non-negotiable.
2. The negative goes from the battery straight down all the way to the lowest part of the frame. There are two bolts about an inch apart, basically behind where the fog lights are. Pick one and attach the cable.
3.1. I ran the final one from the bolt that is directly underneath the big "GROUND" label on the engine block (the bracket that the alternator is hooked to). In the above attachment, look at the red box, there is a red sleeve on my ground point to the left of it. That's the bottom bolt of the alternator bracket. It is directly above the reservoir for your power steering fluid.
3.2. From that point, I ran it up to the firewall at the highest point, basically where the hood meets up with the windshield. There is a factory ground wire right there.
Pics tomorrow.
