bzbatl
Good job on the Big3 - sorry, was out of town for the last few days. I promise, I will have detailed pictures soon
That weaved silver wire is the factory ground.
As far as the pitch of the engine, it's probably the TrueFlow. My S&B made the engine sound much "breathier", even in the cabin.
Operating temp could be due to the weather. It's pretty cold in NJ, isn't it?
Voltage should not be dropping, however... not even a little bit. Once you do the Big3, that voltage meter should be stable at whatever it reads (different based on battery type and the gauge itself).
I'd say get yourself a cheapo multimeter from Wal-Mart and check all your points with the engine off. Hold the positive on the alternator and check your Big3 negative points - they should all register the same.
If not, time to check them all to make sure it's tight and the points are clean.
