JDenhamYukon
- Jan 8, 2012
The front right shows no PSI number ?? Bad sensor ?
Attempt the relearn procedure first. If the vehicle still doesn't recgonize the sensor then most likely it is defective. Cause can range from debris/salt/rain causing corrossion on the device. Pretty inexpensive replacement.
