667theneighbour
- Dec 31, 2008
You don't have to line up the actuator. Just do the self-calibrate I explained earlier.
Did you install the blend door actuator purchased from Rockauto.com? If so, did it fix the knocking/tapping noise? I have the same problem with my 2005 Tahoe right now and don't particularly want to pay $1500+ to get it fixed. If you would be so kind, can you walk me through the process of replacing the actuator or getting the doors to no longer stick?
Alternate Method (w/o Scan Tool)
Clear all DTCs.
Place the ignition switch to the OFF position.
Connect all previously disconnected components.
With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
Rotate the Mode knob fully counterclockwise.
Rotate the Mode knob fully clockwise.
Release the AC button.
Wait 40 seconds for the HVAC control module to self-calibrate.
Start the vehicle.
Verify that no DTCs have set as current DTCs.
Rudolph- You'll need to line up the the teeth from the actuator comb and the vent door combs to where they have full range of motion after reinstalling the actuator motor. All the self calibrating in the world wont help if the teeth are lined up halfway down restricting full movement of the blend door.
Sorry. I meant you don't have to line up the actuator to match the settings on the controls. My bad.
Could a bad actuator also be the cause of hot air (like max heat) to randomly blow out of the front vents even though AC is on/working correctly? Shutting off the engine and restarting causes the AC to return to normal.they can be reprogramed by the dealership. everytime u disconnect the battery you need to possibly reprogram the actuator. the actuators only last a couple of yrs usually. i have replaced mine both driver side and pass. and they are due again to get replaced. i have a 2004. the part cost $250ish from the dealer and you just have to lean under passenger side dash to replace them(black box about the size of deck of cards). kinda tight but doable in under 1/2 hr in your driveway.
