accumulator 99 yukon
skychair
Spider fuel 'O' rings
Looks about right... Why did you not rotate to TDC? If this does not go well you will have to find it. Not hard.....
I just did not think about setting it @ TDC????
I have another question, naturally.
I look down into the fuel line connection on the spider, and I see 2 yellow 'O'
rings installed.
Question is I have 2 small 'O' rings that came with the FelPro gasket kit.
Do I slip these on the fuel line, as added 'O' rings, no additional rings were present when I removed them. A quick look, and there are 2 Yellow 'O' rings in the old spider I removed.
My assumption is that the 2 'O' rings supplied with the FelPro gasket kit are for those that have the quick disconnect @ the fire wall? I wrenched mine off.
Am I correct? just trying to make sure, before I proceed.
Thanks again..................
I would replace the orings. The lines on the firewall are NOT quick disconnect.
skychair
I guess my question could be shortened to if i donot have quick disconnect at the firewall ....i'll not need the o rings in the kit, as the new spider comes with o rings installed?
Am i ok.....
Gotcha! Save 'em for another day, but if NEW injector has 'em use them instead and save the ones in the kit for the next time you tear into it....
