I am looking for some help with my 02 yukon, the blower motor does not work when turning the controls on the computer climate control, i turn to AUTO. and manually turn to on and nothing happens, i went under the dash and checked to see if the blower motor was junk, i disconnected the motor and removed from vehicle and manually bench tested it and the motor works fine, there is a blower motor relay before the motor with 3 wires coming out of it: orange, black and gray/black stripe and then there is a plug with 2 wires going to the blower motor: purple and black. I dont know if the relay is bad is there a way to test it? I get power at the orange wire and the ground is good too. What should i try before i spend money on something i dont need, does anyone have a diagram of the blower motor, blower resistor and blower motor relay? I would appreciate any help from anyone. Thank you very much!
