Gutting a cat will throw a trouble code from the rear o2 sensors for low catalyst efficiency or some such. Rear o2 sensors on all GMs as I understand it (someone correct me if i'm wrong) have no input on anything, closed loop engine management stuff, injector pulse or...anything, they're simply there to throw a code to show the cat isn't working. (you can put a resistor in place of the rear o2s if you don't like the light on the dash) you'll still go into closed loop same as before and timing, ipw and everything else stays the same.
Speaking of gutting cats...can it be done on a tahoe by a guy with just a ratchet, no sawzall and welder involved? those pipes look awful curvy. I want to do my part in going green, can't afford a prius, don't want to buy an obama sticker for it, getting some better mpg with no cats sounds good.
and weird, I thought everyone of us had 2 cats but you have a dual in dual out?[/QUOTWell I will double check on that when my wife gets home but I swore I only saw one cat under there. I dunno maybe it was redone by a previous owner. I do know they make a "ghost" sensor for the check engine light. By cutting the cat out you could save gas and money by getting better gas milege and of course more torque or at least I did on my pickup. that's what I call going green.
I know it says I'm a newbie but I have been reading many articles on this site and I've got to say it has been a great help knowing my hoe isn't the only one with problems such as saggy door syndrome (SDS).:sla:
