mtyler7807
- Dec 10, 2008
THis has been a rough winter. Transmission change time. Got to hit the junk yard this weekend and go get a trans. TO all out there with a little slip in the trans mission. Don't push it to hard. Change the filter and put the same transmission fluid back in. The purpose of that is to make sure that what is in the transmision fluid stays in the fluid. if you where to change it then you will have more problems than you want. Newer transmission fluid might be too thin or too thck and cause it to slip worse. Just change the filter to give it good flow to keep the trans cool. I'll keep you informed on how everything is going. Pretty easy trans to pull and put back in.
