1995 Chev Tahoe 4 door 4 wheel drive
The windshield washer check valve located under the floor near the gas filler neck gave out. Got the replacement (tried 2 of them) which is an ANCO # 48-21 and they do not function properly, and I have mounted it the correct way and the incorrect way. It seems it does not have enough ability to close the valve to keep it from flowing out, and but will open when pump is activated. All it does is allow the whole reservoir to dribble out the spray head on the rear washer arm.
GM can't get one.
If I leave the Tahoe in the drive it is empty in about an hour, so right now it is plugged off.
Any Suggestions as I have no rear wash because of a plastic part. photos attached I hope. Vacuum check valve work??
ron3033 :waytogo:
GM can't get one.
ron3033 :waytogo:
