why dont my back doors stay open???
Sidescrollin
I have a 4door tahoe with rear doors not a tailgate. The damn things wont stay open. Theres some kind of rod or spring that looks like it is supposed to hold the door open but they arent attahed to anything and when the door is open all the way they pop outta the door.
Please help!!! its so annoying loading and unloading things from the back and the doors closing on me! Thanks
98hoe
See if Part #16 is broke. Mine is. But they are made to come uinhooked to open the doors fully and they just snap back in. You have to open the door to a certian point and use your hand to hold the latch (#16) and snap it back in.
Sidescrollin
yaya thats the part im talking about, but how do i know if its broken? it hooks at the end and pops over a piece to attach and comes off like you said but it doesnt look broken on anything....maybe the spring is broken. Must be because it doesnt act like it has a spring it just flops around.
loulblades
Western PA
I have had to replace mine because it appeared to lose the temper on the hook.
If the hook is not broken off the end I suppose you might be able to take it off and pound on it to tighten it up. IMHO I would get new ones.
romiin
thats weired, mine are so tight they hardly open, I oiled the hinges and their still hard to open, I just thought they must be designed that way so they don't swing shut on a you
NoEcm
I found out the hard way that the "hook" is tempered. I tried to squeeze one of mine in a vise to tighten it a little. It cracked and I ended up getting one out of a wrecking yard.
I suppose you could always try heating up the hook with a propane torch and then try to tighten it.
Like loulblades suggests, the best bet would to buy new ones.
loulblades
Western PA
If the doors are hard to open that is a different issue (unless you are talking about the last few inches because that is when the retaining device comes into play). I replaced the hinge pins and the retaining hooks (or whatever they're called), shortly after acquiring my Tahoe and all works great now. The door operates smoothly and even stays open when the multicarrier with the spare tire is pushing against it.
bsamoul
The Bay, CA
my #16 is broken too! how do i get a replacement, and how do I replace it? I'm tired of being smacked by my door haha
loulblades
Western PA
Got mine at the dealer.
To replace #16
Remove the "C" retaining clip off the bottom of the pin.
Pull the pin to remove #16
Install new #16 with pin
Reinstall "C" clip
A few minute job.
I suggest applying grease to various surface allong the way.
qlc1964
st.louis mo.
yeah mine does the same thing pain in the ass when on a incline
putting things in &out hitting my head sometimes when they swing in
but now the left barn is harder to open but it stays open now.
