I'm trying to find TSB 02-01-39-004 and TSB 02-01-38-006
does anyone know where to find these?
heres the info you requested:
FIRST ONE:
Info - New PAG Oil Released #02-01-39-004 - (Aug 12, 2002)
2002 Chevrolet Cavalier
2002 Oldsmobile Alero
2002 Pontiac Grand Am, Sunfire
with 2.2L Engine (VIN F -- RPO L61)
All 2003 Passenger Cars and Trucks
2003 HUMMER H2
General Motors will begin phasing out current service oils for R134a applications. A new GM Universal Compressor PAG Oil has been released and went into production in certain 2002 model year vehicles. Usage will begin in all 2003 model vehicles. The new GM Universal Compressor PAG Oil part number is listed below.
Part Number
Description
Quantity
12378526
U.S. Part Number
6 pack of 8 oz. cartridge
88900060
Canada Part Number
6 pack of 8 oz cartridge
88901445/10-5026
AC Delco Part Number
8 pack of 8 oz cartridge
Parts are currently available from GMSPO.
Use this new PAG oil when servicing the A/C system on the vehicles listed above. The oil is packaged in an 8 ounce tube and should be installed using A/C Oil Injector, J 45037.
The new GM Universal Compressor Oil is compatible with all GM R134a A/C Systems. If the A/C system was previously serviced with a current service oil, no additional repairs are required.
Refer to the HVAC Section of Service Information for detailed information on Oil Balancing and Capacities.
SECOND ONE:
SMU - Revised Compressor Oil Balancing Procedure #02-01-38-006 - (Dec 16, 2002)
2002 Chevrolet TrailBlazer
2002 GMC Envoy
2002 Oldsmobile Bravada
This bulletin is being issued to revise the Compressor Oil Balancing Procedure in the Heating, Ventilation and Air Conditioning sub-section of the Service Manual. Please replace the current information in the Service Manual with the following information.
The following information has been updated within SI. If you are using a paper version of this Service Manual, please make a reference to this bulletin on the affected page.
Draining Procedure
Important
Drain and measure as much of the refrigerant oil as possible from the removed compressor.
Drain the oil from both the suction and discharge ports of the removed compressor into a clean, graduated container. Rotate the compressor shaft to assist in draining the compressor.
Measure and record the amount of oil drained from the removed compressor. This measurement will be used during installation of the replacement compressor.
Properly discard the used refrigerant oil.
Balancing Procedure
Important
The refrigerant oil in the A/C system must be balanced during compressor replacement.
The replacement compressor is shipped with 240 ml (8.0 oz) of refrigerant oil.
Before installing the compressor, the refrigerant oil will have to be partially drained.
Refer to the amount of refrigerant oil recorded during the compressor removal.
Subtract the amount recorded from the total system capacity. Refer to Refrigerant System Capacities. The difference between the total system capacity and the recorded amount is the calculated amount to be drained from the replacement compressor.
Drain the calculated amount of refrigerant from the replacement compressor.
