what should i use to remove the gasket material?
tybardy
i am always scared to remove the gasket material from aluminum parts (tranny filter gasket) and weas wondering what would be a good thing to use to ease my mind?
Rivieraracing
Oregon
Try a plastic scraper to get most of it off or a razor blade (as flat as you can to prevent gouging) ,scrub off the excess some with a scotch brite pad and clean with acetone.
01_Tahoe
Razor blade will be easiest. Like Riviera said, make sure you flatten out the blade so you dont gouge the aluminum.
