Getwired
Did you enjoy that?
Wash: Straight water, no soap.
Wax: Zymol HD cleanser applied by PC and Concourse Carnuba applied by bare fingers.
Interior: Mix of all natural oils.
What do you guys use to get bugs off?
I normally just use a Final/Instant Detailer with a microfiber and gently scrub them off. A lot of times though, if they are fresh, you can just wipe them off with water and a microfiber.
For the old, dried bugs, you can use a very mild multi-purpose cleaner or a very mild wheel cleaner. Either way, dont let the chemicals sit on the paint very long. Also, you'll have to re-wax every area you use a chemical on because those strip the wax.
Agreed! For the ones you can't get off immediately or have "baked on" in the summer heat, I have used >> GASP << isopropyl rubbing alcohol and a microfiber towel and gently wiping it off. It works fantastic. And like you said, you definitely should re-wax the affected/treated area(s). The other wheel cleaners and stuff make me worry about being too harsh on the clear-coat, whereas the alcohol seems to be fine. I've thought of using some gasoline as well -- anyone tried that? Which of these options do you all think is least risky for the clearcoat?
