What part will work ????
schisler
Troy,ohio
hey guys i am new on here and i am looking for some parts. I have a 2003 chevy tahoe z71 am i am looking for the hole rear end. so the question i have is what years and diff. makes will enterchange. Thanks for any help i would like to be able to start driving it soon thanks again
Any coil rear gm suv with the same ratio ring and pinion will work, check your RPO codes in the glovebox or call a dealer with your vin to verify the ratio. I'd imagine a fair number of z71 tahoes and yukons will have the same ratio, those trucks are usually 3.42 or 3.73. Did you bend the housing or why exactly do you need the whole axle housing?
schisler
Troy,ohio
They said it was bent, heres what happened i spun out in it and the impacted the left rear corner, it broke the rim and rotor and caliper it had to be towed home on a flat bed when trying to get it in my garage the left rear axel broke so i replaced axle and caliper and rotor then they noticed when they were putting the new caliper bracket on they said that they noticed that the flang was bent
