Yuke2K
I'm new here, but thought I'd throw in my .02 from experiance with so-called "cold-air" intakes.
Most K&N FIPK systems use plastic tubing and a heat shield, but even so, you are still sucking hot air from the engine bay. Sure, some cool air will filter in from the little hole that the factory airbox used...but you have to realize that the hole was hooked up to a plastic tube running into a sealed airbox - ALL of the engine's air was being drawn from that hole. Restrictive? Yes. Coldest air possible? Yes. K&N does a decent job of compromising between the two, and they sound wicked...but I lost 3 mpg on my '99 4.3 Envoy when I installed one, and didn't feel a damn bit of extra power from that motor despite the dyno sheet included in the package.
The chromie rice pipe intakes from autozone are a joke...marketed to kids with slow fourbangers so that they can impress thier high school buddies with bling and a little extra engine sound. I bought one designed for a civic and threw it on my old '90 bonneville just to add a little sound to the engine. Didn't lose any mpg from that, but I surely didn't gain any. I'm actually suprised I didn't lose any mileage, as the intake track on the 3800s sits about 3" above the exhaust crossover pipe.
The Volant intake seems to be the best design on the market for adding power without drawing an excessive amount of hot air. They pretty much have a sealed airbox without any baffles, plastic tubing with smooth bends, and a large conical filter mounted in the box to maximize flow. They also have an extension pipe that you can mount to the bottom of the box so that you draw cold air from WAY outside of the engine bay. I'm not sure how much of a restriction that is, if any, but it sure seems like they have thier sh*t together on this subject.
I'm planning on getting a Gibson or Magnaflow catback for my Yuke before anything else, then an intake and tuner. I hope to be in the low 20mpg range when all is said and done, but we'll see.
