1. Remove the battery and battery tray from the vehicle.
2. Remove the driver side inner wheel housing from the vehicle. (you can just loosen it where it connects to the washer jug, at the bottom)
3. Disconnect the electrical connector from the washer pump.
4. Disconnect the electrical connector from the washer solvent level sensor.
5. Disconnect the washer hose from the washer pump.
6. Remove the upper bolt from the washer solvent container.
7. Remove the lower bolts from the washer solvent container.
8. Remove the washer solvent container from the vehicle.
© 2008 General Motors Corporation. All rights reserved.
Installation is reverse of removal.
