1996 Tahoe.
Trans started slipping when it shifts from 2nd to 3rd, if you let off the gas when it starts slipping it completes the shift, if you keep the shifter in 3rd it shifts up to 3rd normally.
Once in 3rd you can return the shifter to OD and it shifts into OD normally.
Changed fluid filter still the same.
Suggestions?
Thanks in advance.
Suggestions?
Thanks in advance.
