towing with o5 z71
warwicktahoe
warwick ny
how much could i expect to tow with an 05 z71 tahoe with 3.42 also is there a code to tell if there is a tranny cooler . does the z71 package help with towing thanks tom
sasquatch
harriman N.Y.
if i remember correctly my 05 yukons manual said that the towing capacity was around 7700 lbs.
the most i tow is around 3000 lbs and it handles it very well. i also have 3:42`s.
oomindwarpoo
CA
How do you know the gears? Is it on the pumpkin or somewhere?
667theneighbour
My 04 kan tow 3,45t. I guess the sticker in the glovecompartment can tell you about the gears and other options.
dye4metal
Sarasota, Fl
theres a code in the glovebox that tells you, if you search on here youll find where someone posted it
