tires?
98tahoe2dr
I have a 2 door tahoe and have found some 35" Toyo open country m/t tires that i can buy with wheels and i was wondering if anyone had put on 35" tires with factory height. And if so how bad do they rub and maybe have some pics???
diehardgm
Not gonna fit. 33's will rub most stock height tahoes without crank. You will need a lift to clear those.
98tahoe2dr
Do you know how much lift i would have to have? The cheapest way? And the difficulty?
Crank the tbars with some trimming and they might fit on the stock wheels, otherwise cepek 6.5" is the way to go.
96ProCompTahoe
Indiana
if your trying to do it without a lift, make sure you NEVER hit a pot hole or you'll have it at the body shop... i have a 6 inch lift and 35's still rub a bit in tight turns on the rear of the front wheel wells.
