Hi guys....just changed plugs and wires on my 07 Tahoe and just discovered my temp guage doesn't work.I don't see any wires pulled off but not real sure what I'm looking for.Any suggestions?Thanks.
On the driver side where the front spark plug is there is a sensor with a 2 plug connector thats your temperature sensor it should be between the first spark plug and the topof the power ssteering pump look there in that area see if you accidently disconnected
The plug was in place so I unplugged it and plugged it back in and that fixed it. Now reads like normal. I must have moved just enough to cause an open circuit. Thanks for your help.
