tach
bigdaddy38
Has anyone in here ever put an aftermarket tachometer in a 2001 Tahoe if so how did you do it
Rd05lly
Auxvasse, MO
What are you wanting to do. Lots of options Edge insight CS or CST just plugs into your OBD2.
Or
RED ecm connector pin 10 is tach output signal
bigdaddy38
They make a tach that just plugs into your odb2 what is it called
bigdaddy38
My upgrades is 212/218 with 112lsa and ls6 value springs and a tune from black bear
Rd05lly
Auxvasse, MO
I like the Edge Insight it can read all the ECM PIDs. It is not a tuner just a Obd2 reader plus you can add other gauges to it.
