Steering issues 1999 Tahoe
Bolphur
I just purchased a 99 Tahoe a couple of months ago and have noticed a few quirks. Anytime a make a sharp turn like in a parking garage the steering wheel won't return to center. Instead once when you reach a certain point the steering wheel will turn to the maxed out position. This position will also cause the front tires to chirp or squeal. I had a front end shop take a look at it and they couldn't find anything wrong with it. Is this normal? The Tahoe does turn very sharp. If it's not normal are there some things I can look for?
While I'm here I also have codes P0304 and P0430. They came on this past weekend as I was going up a long grade. They came up twice. I cleared the codes and they haven't come back on. I live in a flat area, so I haven't had to pull any long grades since I cleared them.
P0304 - Missfire cyl 4
P0430 - Catalyst low efficiency bank 2
May have a cat going bad/plugging up on passenger side, may have a bad plug or stuck injector on cyl 4.
