Squeak From Hood
chris48559
So for the last week and a half I have been hearing an almost constant squeak from the driver side wheel area. I decided it is from the hood rubbing the rubber stops, does anyone have any ideas on how to stop it? There are 2 rubber stops I can see, I dont know which one is rubbing. I can take a picture if that would help.
DarkTahoe00
IN
There's 2 rubber hood stop on the core support that you can adjust by screwing them up or down to see if you can get it to stop.
chris48559
Can these be adjusted independently or do they both need to be adjusted the same amount?
DarkTahoe00
IN
I would do both but you can do them independently but one side of your hood will be high or low.
Custom73
Put a rag over them, or some grease and take a drive. See if the noise goes away. Then you know for sure that's your problem.
