Spark plugs
blazerpro202
How in the world do you change plugs on the right side very back on a 2001 Chevy Tahoe
mgfan58
Just finished doing mine so here's how I do it. I have a snap on ratchet, that the head swivels in a u shaped fork. http://image.snapon.com/international/pdf/fhnf100_npa.pdf I put the socket on and tilt it towards the handle. It will clear everything and you slip it slightly past the plug, then bring it forward while lining it up on the plug. Loosen it up until free, then I take the ratchet off and put an adapter, that has a knurled head on the socket, and remove it the rest of the way. IT REALLY SUCKS no matter how you do it. Hope this helps mgfan58
