SES Code
dye4metal
Sarasota, Fl
I got a code Po446
this is what it said on the reader
po0446
MIL ON
Monitors
2 Inc
Catalyst
02 Snsr
5 Ready
Misfire
Fuel COmp
Evap
02 HTR
jey_
St. Louis, MO USA
P0446 - Evaporative Emission Control System Vent Control Circuit
Nothing to do with an O2 sensor or Cat. You could start by checking to see if you tightened your gas cap?
dye4metal
Sarasota, Fl
the chevy dealer said it wasnt the cap. said it was a solenoid in the gas tank. could you point me in the right direction with that?
jey_
St. Louis, MO USA
No, probably the solenoid that controls the gas tank evaporative system. A lot of vehicles have this emissions device that sucks gas tank fumes back into the engine to be burned instead of releasing them into the environment.
dye4metal
Sarasota, Fl
would you happen to know the name that solenoid or part. he said it was a noid on the evap system on top of the tank
jey_
St. Louis, MO USA
I went to Rock Auto and clicked on the 02 Tahoe and it's under "Emissions" since it's an emissions device as I indicated. From there, there's "Vapor Canister Purge Solenoid".
dye4metal
Sarasota, Fl
i figured it was that one, i wasnt exactly sure. is that on top of the gas tank do you know? b.c the dealer said they were going to have to drop the tank and what not
