I have a 2000 chevy tahoe with old body style. I was attempting to replace the pitman arm and failed miserably. I got the center link undone. I also got the nut off the steering box. Only problem is I can not get the pitman arm off of the steering box. I would have used the pitman arm puller like I did with the center link bolt. But there are extreme clearance issues even attempting to use it on the steering box bolt. Sway bar and frame are among the big ones. Although I can easlily take off the sway bar. I also tried using a pitman arm puller/ball joint seperator, but none were wide enough at the forks to even go around the steering box stud.
Is there a technique I am missing?
Anyone have experience replacing these?
