replacing oem nav with aftermarket Pioneer AVH-P4300
lunny7
I have a 2006 3LT Tahoe and I'm just curious as to what I'm going to need to keep all my functions i.e. steering wheel controls, xm, onstar, and rear entertainment system... also how much is this going to cost me. I know a little bit about aftermarket cd players but absolutly nothing about aftermarket nav. I went to my local installer and they wouldn't really tell me much about what I needed just that they could do it. Would rather save some money and get the stuff my self and give it to them to install
lunny7
here are the specs for the p4300DVD
Double-DIN AM/FM radio, DVD, DVD-R/RW, DVD+R/RW, CD, CD-R/RW, VCD, MP3/WMA/AAC, JPEG, DivX receiver
MOSFET 50 Watts x 4 peak power with three 4V RCA preamp outputs for system expansion
7-inch touchscreen display with widescreen 16:9 aspect ratio and WQVGA (480x240) pixel resolution
Features Pandora integration, direct iPod control, playback from USB and SD/SDHC, auxiliary input
Ready for Bluetooth adapter, Satellite/HD Radio, GPS navigation system, rear-view camera
stockergt
you need a couple of adapters and modulation units, there is one to retain the chime, beeps and blips, this one usually maintains on-star as well.
If you want factory steering wheel controls you will need a unit for that as well, I think in all you will be spending an additional 150. Crutchfield often gives you a deal on these things if you order the radio through them. Some thing else you may want to consider is a parking brake bypass for the dvd player.
lunny7
thank you. I ended up changing to a pioneer Avic f900bt and I after doing some research and found out what I needed... one more question do I need the after market mic or can I hook into the stock on star mic
